Need help to ID this nissan
Part-time
I need to find an impeller for it but I can't find a serial number wich I know the parts guys won't even bother looking without...
Does anybody have a clue as to what year this might be?
pvanv
Re: Need help to ID this nissan
Year is unimportant in servicing Tohatsu/Nissan outboards. Critical thing is the precise model/serial. If you have an NS15 C or D2, you will be OK for the immediately foreseeable future with almost all parts still available. But... the D2 would normally be painted silver/gray... with that blue paint... you probably have an NS15B, from the mid/early 1990's. No carb kits available for that model, so treat the carb well! If you have a C or D2, the carb kit is still available.
As for the water pump, the part you want is available from any dealer, including me: Water pump repair kit. Includes all parts (cup, plate, impeller, drive key, bolts, etc.) needed to service water pump. Fits: all 9.9/12/15/18hp 2-stroke models, and all 9.9/15/18/20hp 4-stroke models. DOES NOT fit the 9.8hp model. Part# 362873220M $50.68.
Part-time
Thanks for the info.
Is there a serial number in other places on these motors other than the transom clamp?
I can't find any on this motor.
