NelsonQ
- Aug 5, 2008
- 1,413
Re: Need Help Sizing Trolling Motor
Guess I should've finished my thoughts. For moving the boat forward, you want to stay closer to the center line. If you go far to the port side, you'll most likely need more thrust as it'll create more drag.
No issues with the anchor rope or anchor. The backing plate in the anchor compartment (there is a cleat installed for tying off the anchor mounted there) I installed the quick connect outlet there and then simply screwed a few cable ties in that area in behind to keep the sag out of the cables so when I remove the anchor, etc I don't hook it. Had no issues with it all last season. This will be very obvious once you look in there how to install it.
