michael37659
Thread starter- Joined
- Jul 8, 2009
- 17
I need help in selecting a prop.Im wanting to just get my rpms up in the upper part of the rpm range and and alittle better performance.Any help would very much be appeciated.Thanks
1988 fisher marsh hawk 2v alum. bass
dryweight 453 lbs
10 gal gas
100 lbs of batteries
16ft 4'' long with 69'' beam
1 person
Mostly used for fishing
1972 johnson 50 hp
50hp @ 5500 rpm
5500 to 6000rpm opperating range
12:32 gear ratio
Running jackplate with 6'' setback with antivent plate 3'' above bottom
Running a solas rubex 3 blade prop 13.5 x 15p prop is cupped
max rpms is 5200
top speed is 30 mph [ speedo ] no gps
dryweight 453 lbs
10 gal gas
1 person
1972 johnson 50 hp
50hp @ 5500 rpm
12:32 gear ratio
max rpms is 5200
