I am going to be making some small repairs which will require my working with about a table spoon spoon of gel coat at a time, How much hardner ( Drops ) will I need to mix with a table spoon of gel coat to get a proper cure. I purchased the gel coat which is matched to my color hull from Ranger boats and purchased MEK ( catalyst ) from O'Riley. Also I understand, after an area has been repaired that it should be covered with clingwrap or a material such as a plastic bag in order fo gel coat to cure properly. Thanks in advance for your help.
hereto
hereto
