SS MAYFLOAT
- May 17, 2001
- 6,372
I have 2 Cub Cadets. One is a 72 model made by International, the other is a 2000 model made by MTD. My new one which we use just to mow grass is just a piece of crap. To start it, you gotta crank and crank on it to get it fired up. Then you have to wait for about 5 minuets before engaging the mower so the engine dosen't stall out. The old cub may use oil big time, but it still starts on the first or second hit every time.<br /><br />My problem is with the tire/wheels. My old cub has no problem holding its air. But the new one tends to leak air out of all four. The rims are nicely painted, no chips, cracks, rust or any thing. I have soaped them down. No leaks around valve stem or bead. No punctures to the tires. After they are aired up, they will hold pressure for about a week and then they are flat again. For the first year there wasn't any problem with them loosing air. But now I gotta keep the thing up on blocks so that the bead dosen't break loose from the rim. <br /><br />I think that the rubber in the tires is at its bare minimum, and with them only being a couple of years old, the air is leaking through the tire itself. Is this possible?<br /><br />Has anyone else had this problem with MTD mowers?
