Need Help:Install Fuel Gauge
dccc5102
Does anyone know how, or have instructions/schematic's to install fuel gauge into 1998 19.4' Cobia boat with a 2000 150 Johnson Outboard Motor. Have gauge but can't remember how to install.:confused:
Appreciate all helpful information.:)
Mark42
Re: Need Help:Install Fuel Gauge
Is this the oem / replacement or an aftermarket like Teleflex?
Most gauges have a connection that goes to the fuel tank, and a +12 connection, plus the lighting, but that should be obvious.
Exactly what problem are you having installing the gauge?
Silvertip
The gauge has the following connections:
1) +12 volts -- this connection must be active only when the key is on. This connection can come from the +12V connection on any of the other gauges (Tach, trim, etc).
2) Ground -- this connection can also come from the ground connection on any of the other gauges.
3) Light -- this connection can also come from the light connection on any of the other gauges.
4) Sender -- This connection comes from the fuel level sender in the fuel tank.
5) Sender Ground -- This connection goes to the negative terminal on the battery or to any other ground connection in the wiring harness.
Here is a diagram of the connections:
chiefalen
Now thats how to give advice, diagram and everything.
