haulnazz15
- Mar 9, 2009
- 3,720
Re: Need Help In Oklahoma
I'm not sure what he means by not dewinterizing it but he will start it? He could possibly be talking about not putting the muffs on it to start it for 10-20 seconds, which wouldn't add water to the system. Other than making sure all draincocks are closed, fluids are good, and battery is topped off, there isn't much else to de-winterizing a boat. I would assume the boat has an Alpha I Gen II drive as starting a Gen I without muffs would be a sign to not buy the boat for sure!
Still, it wouldn't be worth your time to drive down there and not have the boat run long enough to get up to temp so that you can check for normal operation. It also allows for plenty of time for the engine to run water through it to make sure it doesn't have a cracked block from the winter allowing water into the oil. Either have him do his dewinterization and run it on muffs/water test, or don't bother with it.
