lowcountryislandhopper
- Mar 11, 2012
- 10
So...just bought a very nice older 15' Henry O (McKee)...awesome boat for island hopping in the S.C. and Ga. coatal deltas. Motor is a 60 Johnson. It sounds like it runs well...no spitting/sputtering or skipping for the most part, cranks right up and idles well (for a few minutes). Two problems I'm having....one is @ low rpm...the motor runs out for 30 seconds or so, then starts to sputter (won't stall), if I hit the key to activate the choke....starts running smoothly again (for a minute or 2). Second prob is @ WOT (or under), the engine again runs out good for a few minutes, then starts surging heavily, pushing the key @ this throttle position does nothing....but pumping the bulb causes the motor to perform as it should, interesting thing is the primer doesn't go slack....still feels like it has plenty of pressure, and if you DON'T pump the bulb, it will surge 5 or 6 times, then go back to running WOT.
What I have done to date to eliminate this problem:
Compression test= 120 psi
Replacement of all fuel lines from tank to fuel pump, new water seperator and inline filter, and primer (I even dropped the end of the fuel line into the tank on a test run to see if the pick up tube or screen was blocked...no change)
Took the fuel pump off (VRO has long been diconnected), took it apart, diaphram looked new, blew through all orifices...no blockage, reinstalled
What I would like to do is rebuild the carbs...seems all I have read is pointing to the low/high rpm orifices being clogged,but I'm having a hard time ID'ing this motor for the carb rebuild kit. Possibly has a new top end. I've read through a lot of articles on here and am still having a problem.
Here is the info I have......numbers on the stainless plug @ top of cylinder=G2250336
numbers on the mounting plate=186684 13BN1 (the B COULD be an R, it's hard to tell)
numbers on all 3 coils packs=582508 22DN-OA
Any advise on the running condition of the engine would be appreciated...and direction on how to ID this thing would be...well...let's just say you'll have made a new friend!!
Thanks in Advance!!!
