Need help identifying part # 331518... Intake Manifold
sr522re
So I bought a used intake manifold for a project I am working on. I need part # 0396790, and found a used one online at a boat dealer. The dealer advertised the part as being # 0396790 which is what I needed. I received the part in the mail yesterday and I come to find out that the #0396790 was painted on as you can see in the picture, but there is an actual stamped number on the lower portion of the intake that says #331518.
Can anyone verify that this is the same part? I have searched all of the parts list and can't find anything that says #331518 on it. I just want to know that I have the right part or not, and if not then I'll need to return this.
Any input is greatly appreciated.
Thanks!
Re: Need help identifying part # 331518... Intake Manifold
Is this for a 22 cubic inch motor ??-------Model # ----Why did you order a replacement manifold.--------The cast # on the manifold is not always the part #
jasper60103
Thanks!
Yea, that 331518 is stamped on both my 30's manifold. FYI. One is '87 and the other is a '88. It must correspond to a mold used for casting the part.
geoffwga1
Important question is:Does it fit? If so you are home and dry.
sr522re
So, to give a little more information, I am trying to convert my 1989 25 hp (TJ25ELCEB) into a 35 HP motor. I'm told this is a pretty common swap during the mid 80's early 90's. All it takes is a manifold and carburetor from a 35 hp model. The manifold I need is # 0396790, but the stamp on the front through me off. I don't know if it fits or not as I haven't tried installing it yet. I just received it yesterday and was considering returning it thinking it might be the wrong part. I measured the intake hole and it does measure 1.5" which indicates it was used on a 35 hp motor, but not sure if all the bolt holes are the same. I guess for $50 I might as well give it a try. I was just curious if anyone could verify the number or cross reference it to the number I need as I haven't been able to find anything on it. As Jasper mentioned, maybe it's just a mold number or something and not the actual part number assigned to this part.
Thanks for the input guys. If anyone else has any new info on the topic I would certainly appreciate it.
And just throwing this out there, I'm still in the market for a used 35 HP carb if anyone has one to sell or knows where I can find one. I need part# 0432705 which is superseded by #0439389.
Thanks,
Chris
