59 evinrude
- Jul 4, 2008
- 22
I got a 1970 45 hp model 457HA. I just got this motor. I set the points at .020 like it said under the flywheel. Took it to the lake and it had no power. I figure I should put in new points and condensers. So, in trying to determine what parts I need, I find some conflicting information in my Seloc manual about what type of ignition I have. One charts states that it is a Type I ignition. The note at the bottom says to set the points at .020 for magneto and .015 for battery type/magnapower ignitions. In a different part of the manual it says that flywheel magneto ignition has coils mounted on stator plate and battery ignition has coils mounted externally. My engine has the coils mounted externally on the side of the powerhead. So what do I have. If you go by the numbers under the flywheel it is a magneto, if you look at the book it says battery ignition. I am stumped. I bought the manual so I wouldn't be confused.
