Need help identifying a jon + transom question
taki
Hello!
I recently acquired an old 16 jon in a pretty good shape overall, with the exception of a rotten transom. Looking and the ID plate, I wouldn't find a lot of info on that specific manufacturer or model (Traveler Boat W23000 Stanray Corporation). Can anyone help identifying her?
Also, the ID plate was attached to whatever was left from the transom. The material looked like a dense cardboard...you can see some of it on the picture. Anyone has an idea what that stuff is? Not sure if original, but in any case strange to say the least.
I'm planning to replace the transom based on the recommendations I found in the forums.
Thanks!
not sure what it is. the two screws in the middle vs rivets in the corners tells you its not original
