NEED HELP,,,gasket on boat drain plug
xxxxxx
The drain plug on my 1965 15' Starcraft (aluminum) lets water into boat. A nice gentle stream.The gasket on there was leather drieded up. Replaced it with a rubber washer, that help but still some water. Put two washers on thinking would compress more but still some water.<br />So any ideas on type washer or material to make one.A boat place told me they don't make that washer anymore,What to use and where to buy washer or material?<br />Would teflon tape help on the threads?...but one has to put new tape each time...that's no fun.<br />That is the only leak. I'm looking forward to a dry boat...<br /><br />Michael
D
DJ
Guest
Re: NEED HELP,,,gasket on boat drain plug
Buy a piece of leather and cut out your own.<br /><br />You could probably use a chunk of old belt.
JAL51974
I use the teflon tape, only takes a minute and no leaks.
