Need Help...Black Max XR2
Painted J Farms
I just bought a boat with the Black Max XR2 outboard. I believe it is a 1987 model. I've been tinkering with it here at home and can't get it to start....Upon further evaluation I found out that the left (looking from the rear of the motor) side cylinders arent getting any spark, but the right side is...I'm really unshure where to go next. I'm new to outboards and need help with the fix....and suggestions?
j_martin
Re: Need Help...Black Max XR2
Swap the switchboxes around. If it's a switchbox the bad side will move. If it's the stator, it won't.
Stator or switchbox usually gets one side. Trigger usually gets one on each side.
hope it helps
John
CharlieB
Switch box test , disconnect the 'bias' wire, the very top left wire that links the boxes together, retest spark, DO NOT ATTEMPT TO START without bias connected BOTH BOXES should fire at the same time.
If both boxes now fire the problem is a bad bias circuit in the box that ALWAYS fired. Strange, but true.
Manuals very highly recommend to replace BOTH boxes, as the bias in the 'good' box, the un-firing one, will soon go out from the additional stress that it has been loaded with.
NOTE: BOTH boxes will work fine an a 3 cyl 75 - 90 hp, just paint/mark them as 'bad bias'
Painted J Farms
Still no luck....I'm not really shure about unhooking wires on a motor that I know nothing about...lol, I think I'm just going to take it to the boat shop...Any idea what those boxes might cost if replaced? :confused:
CharlieB
Dealership may be costly, 1/2 hour to test, 1/2 hr each to change another 1/2 hr to re-test.
Could be up to 2 hrs
boxes 225 each
You CAN DO this, it is not difficult
the first test for the bias, identify the bias wire
boxes have 2 rows of terminals running lengthwise and one row crosswise
The bias terminal is the far left on the crosswise row.
Disconnect that terminal wires on BOTH boxes, pull the plugs and test for spark, repost with results and we will walk you through the next test.
rndn
Buy a good outboard manual for your merc. Don't try this without a manual as it sounds like you are very unsure of tinkering with it.
