NEED HELP ASAP!!!!! Mercruiser 4.3 thunderbolt IV
achris
More fish than mountain goat
Look in the stickies that Bondo pointed you at. I have a bunch of videos on a few things about outdrives.
a8218
I downloaded the files also ordered the seloc book......I pulled my outdrive as I suspected I would have to change the lower shift cable anyway. Come to find out apparently the small square head set screws that clamp the shift cable in the plastic connector rod had slipped. So nothing major. With the drive off shifting by hand the outdrive shifts as it's supposed to and the cable is easily moved by hand. I'm going to go ahead and replace the gimbal bearing while I have the drive off and it looks a little gummed up and I have to wait on gaskets anyway. Thank you all for the help I greatly appreciate it.
