Just bought a boat with '89 evinrude. Installed new water pump. Was running ok, but since the motor was sitting up for probably a year or so I figured the carbs needed going through. My brother cleaned the carbs, put the linkage, etc. back like it was. Now when we crank the motor it revs VERY high. I have to turn the motor off it revs so high.
One thing to NOTE, he said when he first took carbs apart that the FLOAT needle was NOT hooked to the pin on the float. So he hooked the float needle to the pin. I don't see why this would make the motor idle real fast. Sound to me like an AIR LEAK. But where???
We are supposed to go fishing tomorrow, advice needed ASAP. Thanks.
