Need help analyzing these dva results - 1985 black max 200
CamaroMan
Sn is 628*** 200 black max, 1985 iirc- comp is fine on all 6, 120 across the board..
Intermittent spark across most cyls, but cyl 4 is awful, on and off, fluttering about-
I double checked the kill switch (yellow/black wires removed made no difference)
I also disconnected the reg/rect (no difference).
Carbs just rebuilt, max timing set at 20 degrees cranking, idles around 6 degrees ATDC-
Huge puffs of smoke on startup and a really nasty eye burning smell (unburned fuel). I mixed a fresh mix of 50:1 for testing. Battery fully charged and all connections in good shape.
Here are the results.. intermittent spark across multiple banks but #4 is the worst..
DVA: (motor idling)
2-4-6 (outer switch box/YELLOW sleeve):
purple to gnd: 4.3v
white to gnd: 15v *** this ones the worst, spark is on and off
brown to gnd: 4.3v
Blue (low speed) to gnd: 314v
Red to gnd (high speed): 198v
1-3-5 (inner switch box/ BLACK sleeve):
purple to gnd: 5v
white to gnd: 4v
brown to gnd: 6v
Blue (low speed) to gnd: 266v
Red to gnd (high speed): 203v
Stator (2 yellow wires): 92v (at idle)
Bias circuits (wire disconnected and measured terminal to ground):
Both: 960 ohms (ill have to recheck 2moro to make sure the k or M wasnt appearing, it was dark with a headlight), "should" be 9000 or 15000 depending on make ive read.. so IF this is outside those specs could the switch boxed also be bad?
CamaroMan
Trigger ohm readings are all in the 600-700 range-
QBhoy
Is your battery maybe duff and broken up inside. This can happen but still be ok enough to start the engine and take a charge from engine...but ultimately be bad enough to affect the engine. Especially at higher rpm. Happened to me twice. Once on an outboard and once on a 2 stroke jet ski. Totally threw me.
maybe not the case, but worth trying another battery maybe.
QBhoy
Think you’re stator is maybe suspect, just reading again maybe ?
when you disconnect the rectifier, did the charge to the battery drop or not ? This would tell a story. Put your meter on the battery and pull the rectifier and see. Just to rule that and stator (in part) out perhaps.
Faztbullet
Considering #4 trigger coil also operates #2 cylinder I doubt its the trigger. Swap box postions and retest to see if problem followed the box. If so swap as a pair. If engine has a idle/advance box disconnect it. You can check bia's voltage with regular meter. Engine running ,meter set at 20VDC..if using a DVA meter set to 20VDC not 20 DVA. Red to ground and blk to terminals should read NEG 10-30 volts at idle. If in spec disconnect rectifier and check switchbox output.
