Need help 80's 200 hp v6
mgeistman
I can't figure out why it's bogging out when I put it in gear. In nuetral it revs up fine but when I put it in gear as soon as I give it any throttle it bogs down and will die, then it starts right back up just fine.
Things I've done:
New spark plugs
Pulled off carbs and the fuel bowls sprayed carb cleaner threw all the jets and orifices I could find.
New fuel filter and fuel line
Checked spark on all cylinders
Did a compression check with my finger
I feel like it's not getting fuel but it will rev up no problem. I'm stumped.
jakedaawg
How did you check spark?
Needs a compression test.
Try a cylinder drop test. Pull plug wire off individually one at a time while in gear under load and note rpm change. This will helpnfind the bad hole.
Model #would be nice
mgeistman
I checked the spark by pulling out the plugs and grounding them while cranking it. They all had good hot spark. I also got a compression gauge today and all cylinders had 100-105psi. I also checked the fuel pumps and there working good.
emdsapmgr
You have an incorrect model number. There is no "L" Could it be a "C"? 1981? Any V6 will seem to run just fine on only 3 cyls when running on the garden hose on the trailer. You really can't tell how many plug are firing without testing. You need all 6 firing in the water when it goes into gear. Sounds like not all 6 are firing...
jakedaawg
Guessing EIB 91
You need to do an open air gap spark check set to 7/16". This is a.must. the tool may cost as little as $15
mgeistman
No Title
emdsapmgr
I think the serial # you gave us was missing the last digit, which is barely shown on the serial plate: E200TRLCII. That would make it a 1981. The far right letter is an internal work/job letter (I) and is of no consequence. Spark plugs tend to fire when removed from the plug hole and the plug is touching the side of the block. Its another thing when you want it to fire when screwed into the plug hole-at 5000 rpm and under hard compression. Takes a lot more voltage to fire it at 5000 than at idle. So you could have spark when doing static testing, but not when running it hard.
mgeistman
So if I find that the spark is weak should I go after the coils or the stator?
interalian
Looks like the last letter is a "B" for what it's worth (which is of no consequence, as you stated).
emdsapmgr
I find that the 6 coils are generally pretty reliable. So are the stators. To start testing, it would be good to know which plug is not firing. If you put a timing light on each plugwire while running, you may see a misfire. If it's one plug, that's one thing, if it misfires all of them on occasion, that's another. I would check out the stator and timer base first. Read through the troubleshooting guide specific for your engine at: cdielectronics.com. This guide shows how to measure cranking voltages for both those devices-if you have a special "peak reading" voltmeter. You should get something like 150-400 volts on each stator leg and something like 0.6 cranking volts on the timer base. If both check out, that's great. Then you get into the packs and coils. The packs you can swap. If you have a misfire on one head, then swap the power packs and the misfire moves to the other head-that tells you it's likely the pack. You can't just start buying new parts without knowing what's defective. The parts are just too expensive.
mgeistman
Ok I did a open gap spark test and it popped a 7/16" gap no problem. I put it in the water and tested it and when I pushed in the key for the primer solnoied it would try to take off but when I let off the key it would die. Seems like it's gotta be a fuel issue. I'm thanking I should pull the carbs apart again and clean them.
jakedaawg
All three, completly apart, including all the jets,(there are four removeable at least if I remember) pull the core plugs, clean completely.
