ILDUCKHUNTER
- Jun 11, 2002
- 5
Hello<br />I have a 1992 40hp johnson and I had to pull the flywheel the other day to replace the power pack. Everything went smoothly, flywheel came off easy etc... I got everything back together and now I can not get the motor started! I checked for spark and I have Good spark at both cyclinders. Is is possible to messup the timing when you pull the flywheel? I wouldn't think it would be an issue since the wheel is keyed so it has to to back on the same way! Any help appreciated. What do you think a dealer would charge me to check my timing for me. I don't have a light and have never messed with timing. Is it something that you could explain to me how to check? I would consider myself pretty mechanically sound. Thanks
