TheBigSur
Thread starter- Joined
- Oct 5, 2017
- 17
Hi iBoat Friends,
I was helping my Dad with some maintenance on his 1998 Mercury Outboard (Model 115EXLPTO/Serial Number OG691795). We removed the lower unit to replace all the oil seals due to water in the gear box. After removing the cover from the shift shaft, I accidentally pulled up on the shift shaft. Much to my surprise, it came completely out of the lower unit gearbox. I noticed that it had splines on the end and it very different from my 2001 Johnson outboard which actually screws into the lower unit.
The shift shaft on the Mercury 115 is actually divided into an upper shift shaft with a "female spliced end" (which remains in the housing) and a lower shift shaft with a "male spliced end" (which is removed with the lower unit). So here is my dilemma: When I try to place the lower shift shaft back into the lower unit gearbox via it's tube (with a small hole in the bottom), it goes down pretty far and then meets resistance. When I turn the shift shaft (clockwise or counter-clockwise), it only spins in place, but does not engage the gear box to change from forward, to neutral, or to reverse. Do I have to pull the bearing carrier to re-seat the shift shaft? What do I need to do to re-install the shift shaft correctly so it will change the gears? Any help is appreciated...thank you!
