Need help: ´72 Chrysler 30 HP- How to "tune" ignition
WillyBWright
Yes, turn the crankshaft until the points are at their widest and set the gap there. Mark that spot on the cam and turn the crankshaft until it lines up with the other set and adjust those. Many public libraries have service manuals. You should check yours. :) Unfortunately that doesn't help you much on a Sunday. ;)
Your English is fine. :)
WillyBWright
Re: Need help: ´72 Chrysler 30 HP- How to
That would be a good place to look. The points may be at different gaps.
eurolarva
Your problem is probably the carburator not the timing. There is a carburator mixture screw on the top of the carburator above the choke. Slowly turn clockwise till it lightly seats while counting turns. Should be around 1 1/2 turns. If you follow where this screw would end in the carburator you will see a little round disc about the size of a phenning. This is called a welsh plug. Under that plug is three tiny holes and if one of these holes is plugged or gummed up you will have idle problems. If you take the carb off remove the mixture screw and spring and open the throttle plate and you should be able to see these holes without removing the welsh plug. Take a thin piece of wire and some carburator cleaner and clean these holes. With compressed air blow the holes from the carburator out the hole the mixture screw was in. Replace and reset the mixture screw and let motor get warmed up. When warm engage motor in forward gear at as low an idle speed as you can maintain so motor wont kill. Adjust the screw clockwise till motor races (lean), adjust anticlockwise till motor starts to stumble (rich) then adjust the screw midpoint between both adjustments.
Good luck and post back with any other quesitons
