Need advice before spending money at repair shop
mksharpe
I have a 1980 Mercury 40HP. I think its a 402 model. It has a low serial number: 5751103. It was running fine until one day it wouldn't start good and then backfired. It finally started so I took it out to the lake and it bogged down when opening up the throttle. I was told it might be the carburetor so I took it off, cleaned and rebuilt it. It started good on hose in the yard. Took it back to the lake and had the same problem. Ran real slow and bogged down when trying to accelerate.
So I took it to the local repair shop. They tested and said it was firing on only 1 cylinder. They said it was probably the switch box and also the wiring is a little shot on a few of the leads going into the switch box. Looking at $500 to repair!
My son happen to mention that when he was trying to start it, the flywheel hung a couple of times. He noticed a magnet sticking down from under the flywheel and it seemed it was keeping it from turning. He said the magnet came completely out and he didn't put it back in.
So I am wondering if its not the switch box but something else like the stator? Should I get the boat back from the repair shop and try and replace the stator myself, or tell them to look at the stator instead of the switch box. Obviously they didn't notice the magnet missing.
Thanks.
Georgesalmon
Re: Need advice before spending money at repair shop
Ummmm, I think you need that magnet to create a trigger to fire that other cylinder. Won't fire a new switch box with out it.
mksharpe
So the switch box is probably ok? I'm assuming the magnet is part of the stator? How hard is that to replace and can it be done at home?
Snowfish
A magnet being gone will definitely be a problem. That issue needs to be addressed first. May need a new flywheel. Not sure it the magnet is glued or bolted. Probably glued.
Throwing a switch box at it will only produce the same results. When it is running, or some what running, leave the air box/silencer off while testing. Note the carburetor intakes while giving it a couple burps. If gas is shooting Out of the carbs, the reeds are bad.
I know this first hand. I was convinced that I had a corrupt switch box. $300 later, self installed trigger box, and the same problem remained that you are experienceing. Left the air box off, while testing again, and noticed gas spraying Out of the center carb.
New reeds going in next spring. Our season is done anyway.
Georgesalmon
Don't know if the switch box is OK. Still, even if it is it won't work without the magnet. Might be able to find a used flywheel if you search around enough. They are pretty bullet proof,,,,,,,unless a magnet falls off of course.
