need a year for my seaking
sharples1949
i have a 35 hp seaking outboard modle # gg8997a, i would like to know the year , and manufacturer. thank you. allemary
CATransplant
Re: need a year for my seaking
That's a 1958 35 hp, made by Gale, a division of OMC, manufacturers of Johnson and Evinrude outboards.<br /><br />You're in luck with this motor. Parts are readily available. It's essentially the same as the RD-19 Johnson 35hp model. <br /><br />Fuel:Oil mixture is 24:1 (1qt. per 6gal of 87 octane gasoline)<br /><br />When looking for parts, you're looking for parts for that 1957-58 RD-19 or RD-19C Johnson outboard. Ignition parts and carburetor parts are easy to find, since they are carried by Sierra Marine, available at all NAPA auto parts dealers.<br /><br />Point gap is .020"<br />Spark plug should be a Champion J6C, gapped at .030"<br /><br />Many other parts are available at your local Johnnyrude dealer, although you may find that you have to convince them that they still have these parts. <br /><br />I believe the only real difference between this motor and the RD-19 is that yours will have a fuel pump, so it uses the single line gas tank, rather than the 2-line pressure tank. <br /><br />Lots of owners of these Big Twin engines here. To get help, post questions on the Johnson/Evinrude form, referencing the Johnson RD-19 in the title of your threads. You can explain in the message that it's a Sea King.
sharples1949
thanks alot for the date of my seaking, and all of the info on it, you have been a tremendous help.it has so much kicking power for it;s age. thanks again. allemary
sharples1949
hi again , i;m looking for another id. on a different motor , i only have a modle # rdel-17 year probably in the 50;s. thanks , allemary :confused:
sethboat
I have a question about a 25 hp sea king GG8992A. I got it without a gas tank and without manual. I'd like to find out what year it is and what kind of tank it needs. Do I need a pressure tank or does it have a fuel pump? What kind of oil mix does it use? Where would one find a tank for it and what would be the ball park price for one? Where would I find parts? Is it a Johnnyrude knock off with interchangeable parts? <br /><br />Thanks in advance!<br /><br />seth
