Need a replacement fender
19bee70
First time post and I'm hoping someone sells or can tell me where to find a replacement fender for my trailer. A blowout took my fender out and I can't find a fender my size. The easy part is the 9" wide but who makes a single axle fender 74" long with top and front/rear steps??? All I can find is the usual 40-44" versions. If I have to buy 2 to match, I might have to. :(
Bifflefan
Re: Need a replacement fender
Welcome aboard.
Really? A 74" fender on a single axle? I'd like to see a pic of that. That is big enough for a 3 axle trailer.
Bob's Garage
It would help to know the name, model and age of the trailer if known. A brand still in production can be contacted for replacement parts.
I had to get a fender for my Float-on from them when the fender was damaged as it was not a common size.
tpassmore
best to contact the trailer mfr. sb a label close to the tongue with model # and name. they'll ask you to send a pic for confirmation. its very difficult to find generic fenders that fit.
19bee70
Yep....my first thought was to ID the maker and model but no data plate. It really is a one piece fiberglass fender with 5 welded supports. It is a painted steel trailer for a fresh water boat. Mine is an 18ft Hydrostream. The blowout broke 3 of the 5 supports right off the trailer. My second thought is to grind the broken welds smooth and modify the trailer frame to support a more conventional 40" fender.
