need a pic of throttle cable connection to manifold bracket
mikomos
Hi i have an aq211 , can somone explain or show a pic. Of a clip or anyi other part the throttle cable to the manifold bracket. I have it wired bebecause cause i cant find what ever it is im missing?
Don S
Re: need a pic of throttle cable connection to manifold bracket
It's not missing anything, and you shouldn't need to wire it down like that. As long as the cable is attached to the carb, it can't come out.
To remove the cable, you have to disconnect the cable from the carb, then lift the cable from the bracket and pivot the cable about 45? up at the carb end to get it out of the bracket.
