Need a Pic of a...
lmannyr
Master Chief Petty Officer
I'd like to upgrade my toggle switches (half are falling apart) to illuminated rocker switches. I'm trying to figure out what pulls through the panel and holds it in place.
Can someone post pictures a rocker switch with the rocker removed please. I'd like to see the back of the rocker too. Thanks!!!
lmannyr
Re: Need a Pic of a...
Oh never mind. There installed by pushing through the panel and locking in place.
What is the best way to cut the rectangle holes for these rocker switches?
thanks!!
rndn
I have used a Dremel tool in the past with great results. I used a cutoff wheel attachment.
fdmsiv
You can get "boxes" for the rocker switches to sit in. The boxes then can mount to a thicker material than just the switch.
You can connect the boxes together to make a gang of switches.
Best switch selections and accessories I found here:
http://genuinedealz.com/
