DukesFin
- Oct 12, 2005
- 504
Okay, here is the boat/issue I am having...
1974 OMC GM L6 250 cid motor. I've got electronic ignition and always have. The problem I am having is it seems the engine "boggs down" after running WOT for a couple of miles. I'll be doing 35 mph for a couple of miles, then she runs like I have an obstruction in the fuel line, bogging down, forcing me to slow to around 20mph, then 15 or so, then to 5. At this point, I anchor the boat, turn it off and sit for a while, letting her cool down. Once cooled off, I crank her back up, and she runs great... for a couple of miles until the "bogging down" issue begins again.
By "feeling" and "hearing" it when I'm driving, I have realized it is an ignition issue instead of fuel delivery problems that I am having.
I know coils can overheat and cause similar issues, and I know that condensers can go bad and cause these issues. I don't have my boat up here in Atlanta with me, it's down in Florida so I can't run out to check if I've got a condensor or not. What I do know is that I've got Pertronix Electronic Ignition, a coil and a BALLAST RESISTOR. I do not have a "special" coil, just the stock MARINE coil and I do not have an ignition module "box" either...
So, my question is, can anyone tell me if I do have a condenser INSIDE my distributor cap? Should I replace the coil, ballast resistor and condensor (if I have one)?
Any help would be greatly appreciated!
Duke
Duke
