Re: Need a motor and bracket for 17' Proline!
you could mount a conventional engine on the bracket,but it will be alot of work ,you will need to get to upper motor mounts which means pulling the powerhead of the replacment eng,unfortunatly,the seadrive pats are becoming very scarce,so most ,as I now am,putting a manufactured bracket on the hull after glassing up the holes,then mounting an eng of your choice,if you stay with OMC,you can reuse all the wiring,controls and depending what steering config,you have maybe adapt.mine useda cable,some hydraulic could be reused ,but you may need a new ram.There is a good cable unit avail.called NO-FEEDBACK,you dont have the wheel travel like yrs.ago and far cheaper than hydraulic
