- Mar 8, 2009
- 44,430
Been having issues with the marina watt hour meter reading high. Discussed the issue and they were open to testing, so I kept everything disconnected (OFF) and the next day the meter clocked up move watts. So I picked up a watt hour meter (EKM-15IDS ) which is a signal phase 50 amp unit which uses a DIN rail type mount.
I want to install the meter in a clear lid box so the reading can be viewed without opening it. Also want it to be rain tight, even though it will be used in covered slips well away from rain, but may be splashed with hose over spray. Also want to install a 120V GFCI outlet inside under the lid. I could cut an opening for the meter and the outlet in the box, sealing the meter face and use a cover for the outlet. Plan to use water type cable connectors and have the 30 Amp 3 prong shore power connector
The meter measures 4x3x2.75
Think of a 8x4x3 would be great but having a hard time finding it. The manufacture has one which will work but these guys want $100 for it, good grief. It measures 10.63x6.7x4.33
Looking for other ideas
