Need 1993 Yamaha 200 TXRR torque specs Please!
gill
I need the torque specs for the cylinder heads, connecting rods, and the crankcase inside and outside bolts. It would be greatly appreciated!
Fleet Master
Re: Need 1993 Yamaha 200 TXRR torque specs Please!
If you are still looking for this I have the Clymer's Manual and these are the Specs it states.
- cylinder head bolts: Step 1- 11 ft-lbs, Step 2- 22 ft-lbs
- cylinder head cover bolts: Step 1- 2.9 ft-lbs, Step 2- 5.8 ft-lbs
- connecting rods: Step 1- 12 ft-lbs, Step 2- 27 ft-lbs
- crankcase to cylinder block bolts:
8mm bolts: Step 1- 7.2 ft-lbs, Step 2- 13 ft-lbs
10mm bolts: Step 1- 15 ft-lbs, Step 2- 29 ft-lbs
I hope this helps.
