mikemerrill50
- Dec 3, 2005
- 84
Hey guys. It's been a while since I've posted, and now I'm ready to get back to work on my boat. The picture below is a bit out of date, because I have since removed the foam from the hull, and have since repaired the stringers.
Here's what I'm wondering: I am looking into putting an below-deck gas tank, v-style. However, I know I will obviously have to remove a section of the center stringer, but I might have to remove part of the nearest stringer on either side. What would be the best method of doing this? I was going to cut the stringers where I would need them cut, add some layers of fiberglass to the hull below where the tank would go, and build a frame around the tank to be covered with fiberglass (and of course take into account the expansion of the tank, yada yada). I am also thinking of using heavier foam for added floor and hull support. How does this sound?
Thanks always,
Mike
Here's the link to the picture:
http://rides.webshots.com/photo/1530717708066244682rUSdXy
P.S.... on another note, I the sides of the hull seems a little too flimsy for my tastes. Should I stick with the manufacturer design, or would it be ok for me to add layers of fiberglass to the inside of the hull to strengthen it? Thanks again.
Thanks always,
Mike
