Nav light
tytim
New at this. Where do I connect the two wires from the white nav light. They were never connected to the nav switch. The R/G is ok and works off nav switch. does anyone have diagram?
flargin
Re: Nav light
Welcome to the forums.
depending on if you have a switch for it (up for navigation, down for anchor, middle for off) you would follow Silvertip's advice here: http://forums.iboats.com/showpost.php?p=2100139&postcount=4
if you don't have a special switch and just want it to turn on with the nav lights... just wire one end to the switched side, and the other wire to a ground wire (usually black)
