FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
my front green/red navigation light isnt working... i took it off and put a voltmeter on the 2 wires... i'm getting a reading of .59 volts....what should i be getting there? the fuse is good.... any troubleshooting help would be appreciated
You should be getting 12 volts. If the fuse is good and the fuse holder is corrosion free check the ground wire. Also make sure you have 12 volts going into the fuse.
