Re: Nautical Terms/Definition Category
The "B" Section
B
Back and fill ? To use the advantage of the tide being with you when the wind is not.
Backstays ? Long lines or cables, reaching from the rear of the vessel to the mast heads, used to support the mast.
Baggywrinkle ? A soft covering for cables (or any other obstructions) that prevents sail chafing from occurring.
Bank ? A large area of elevated sea floor.
Banyan ? Traditional Royal Navy term for a day or shorter period of rest and relaxation.
Bar ? Large mass of sand or earth, formed by the surge of the sea. They are mostly found at the entrances of great rivers or havens, and often render navigation extremely dangerous, but confer tranquility once inside. See also: Touch and go, grounding. Alfred Lord Tennyson's poem "Crossing the bar", an allegory for death.
Barrelman ? A sailor that was stationed in the crow's nest.
Bar pilot ? A bar pilot guides ships over the dangerous sandbars at the mouth of rivers and bays.
Beaching ? Deliberately running a vessel aground, to load and unload (as with landing craft), or sometimes to prevent a damaged vessel sinking.
Beacon ? A lighted or unlighted fixed aid to navigation attached directly to the earth?s surface. (Lights and daybeacons both constitute beacons.)
Beam ? The width of a vessel at the widest point, or a point alongside the ship at the mid-point of its length.
Beam ends ? The sides of a ship. "On her beam ends" may mean the vessel is literally on her side and possibly about to capsize; more often, the phrase means the vessel is listing 45 degrees or more.
Bear ? Large squared off stone used for scraping clean the deck of a sailing man-of-war.
Bear down or bear away ? Turn away from the wind, often with reference to a transit.
Bearing ? The horizontal direction of a line of sight between two objects on the surface of the earth. See also "absolute bearing" and "relative bearing".
Beating ? Sailing closer to the wind than about 60? (see also reaching, running and tacking).
Beaufort scale ? The scale describing wind force devised by Admiral Sir Francis Beaufort in 1808, in which winds are graded by the effect of their force (originally, the amount of sail that a fully-rigged frigate could carry). Scale now reads up to Force 17.
Before the mast ? Literally, the area of a ship before the foremast (the forecastle). Most often used to describe men whose living quarters are located here, officers being quartered in the stern-most areas of the ship (near the quarterdeck). Officer-trainees lived between the two ends of the ship and become known as "midshipmen". Crew members who started out as seamen, then became midshipmen, and later, officers, were said to have gone from "one end of the ship to the other".
Bend ? A knot used to join two ropes or lines. Also see hitch.
Belay ?
1. To make fast a line around a fitting, usually a cleat or belaying pin.
2. An order to halt a current activity or countermand an order prior to execution.
Belaying pins ? Bars of iron or hard wood to which running rigging may be secured, or belayed.
Berth ? A bed on a boat, or a space in a port or harbour where a vessel can be tied up.
Bermudan rig ? A triangular mainsail, without an upper spar, which is hoisted up the mast by a single halyard attached to the head of the sail. This configuration, introduced to Europe about 1920, allows the use of a tall mast, enabling sails to be set higher where wind speed is greater.
Best bower (anchor) ? The larger of two anchors carried in the bow; so named as it was the last, best hope.
Between the Devil and the deep blue sea ? See Devil seam.
Bight (pronounced /bаɪt/) ?
1. Bight, a loop in rope or line: a hitch or knot tied "on the bight" is one tied in the middle of the rope, without access to the ends.
2. An indentation in a coastline.
Bilge ? The bilge is the compartment at the bottom of the hull of a ship or boat where water collects so that it may be pumped out of the vessel at a later time.
Bilge keels ? A pair of keels on either side of the hull, usually slanted outwards. In yachts, they allow the use of a drying mooring, the boat standing upright on the keels (and often a skeg) when the tide is out.
Bilged on her anchor ? A ship that has run upon her own anchor, so the anchor cable runs under the hull.
Bimini ? Weather-resistant fabric stretched over a stainless steel frame, fastened above the cockpit of a sailboat or flybridge of a power yacht which serves as a rain or sun shade.
Bimmy ? A punitive instrument
Binnacle ? The stand on which the ship's compass is mounted.
Binnacle list ? A ship's sick list. The list of men unable to report for duty was given to the officer or mate of the watch by the ship's surgeon. The list was kept at the binnacle.
Bitt ? A post mounted on the ship's bow, for fastening ropes or cables.
Bitter end ? The anchor cable is tied to the bitts, when the cable is fully paid out, the bitter end has been reached. The last part of a rope or cable.
Blue Peter ? A blue and white flag (otherwise the flag for the letter "P") hoisted at the foretrucks of ships about to sail. Formerly a white ship on a blue ground, but later a white square on a blue ground.
Boat ? A craft or vessel designed to float on, and provide transport over, water.
Boatswain or bosun (both pronounced /ˈboʊsən/) ? A non-commissioned officer responsible for the sails, ropes and boats on a ship who issues "piped" commands to seamen.
Bobstay ? A stay which holds the bowsprit downwards, counteracting the effect of the forestay. Usually made of wire or chain to eliminate stretch.
Bollard ? From 'bol' or 'bole', the round trunk of a tree. A substantial vertical pillar to which lines may be made fast. Generally on the quayside rather than the ship.
Bombay runner ? Large cockroach.
Bonded Jacky ? A type of tobacco or sweet cake.
Booby ? A type of bird that has little fear and therefore is particularly easy to catch.
Booby hatch ? A sliding hatch or cover.
Boom ? A spar attached to the foot of a fore-and-aft sail.
Booms ? Masts or yards, lying on board in reserve.
Boom vang or vang ? A sail control that lets one apply downward tension on a boom, countering the upward tension provided by the sail. The boom vang adds an element of control to sail shape when the sheet is let out enough that it no longer pulls the boom down. Boom vang tension helps control leech twist, a primary component of sail power.
Bottomry ? Pledging a ship as security in a financial transaction.
Buoy ? A floating object of defined shape and color, which is anchored at a given position and serves as an aid to navigation.
Bow ? The front of a ship.
Bow-chaser, chase or chase-piece ? A long gun with a relatively small bore, placed in the bow-port to fire directly ahead. Used especially while chasing an enemy vessel to damage its sails and rigging. (quoted from A Sea of Words)
Bowline ? A type of knot, producing a strong loop of a fixed size, topologically similar to a sheet bend. Also a rope attached to the side of a sail to pull it towards the bow (for keeping the windward edge of the sail steady).
Bowse ? To pull or hoist.
Bowsprit ? A spar projecting from the bow used as an anchor for the forestay and other rigging.
Boy seaman ? a young sailor, still in training
Box the compass ? To state all 32 points of the compass, starting at north, proceeding clockwise. Sometimes applied to a wind that is constantly shifting.
Brail ? To furl or truss a sail by pulling it in towards the mast, or the ropes used to do so.
Brake ? The handle of the pump, by which it is worked.
Brass monkey or brass monkey weather ? Very cold weather, origin unknown. A widely circulated folk etymology claiming to explain what a brass monkey is has been discredited by several people including Snopes [2] and the Oxford English Dictionary.
Bridge ? A structure above the weather deck, extending the full width of the vessel, which houses a command centre, itself called by association, the bridge.
Bring to ? Cause a ship to be stationary by arranging the sails.
Broaching-to ? A sudden movement in navigation, when the ship, while scudding before the wind, accidentally turns her leeward side to windward, also use to describe the point when water starts to come over the gunwhale due to this turn.
Buffer ? The chief bosun's mate (in the Royal Navy), responsible for discipline.
Bulkhead ? An upright wall within the hull of a ship. Particularly a load bearing wall.
Bull of Barney ? A beast mentioned in an obscene sea proverb.
Bulwark (pronounced /ˈbʊlək/) ? The extension of the ship's side above the level of the weather deck.
Bumboat ? A private boat selling goods.
Bumpkin or Boomkin ?
1. A spar, similar to a bowsprit, but which projects from the stern. May be used to attach the backstay or mizzen sheets.
2. An iron bar (projecting out-board from a ship's side) to which the lower and topsail brace blocks are sometimes hooked.
Buntline ? One of the lines tied to the bottom of a square sail and used to haul it up to the yard when furling.
Bunting tosser ? A signalman who prepares and flies flag hoists. Also known in the American Navy as a skivvy waver.
Buoyed up ? Lifted by a buoy, especially a cable that has been lifted to prevent it from trailing on the bottom.
By and large ? By means into the wind, while large means with the wind. By and large is used to indicate all possible situations "the ship handles well both by and large".
By the board ? Anything that has gone overboard.
