Re: Nautic star 210DC best prop?
Hi Commander,
Sorry to have taken so long to get back with data. My health is poor, didn't get my boat back in the water till last week, my wife broke her arm 1st day on the boat, weasels attacked us, You know the drill!
Anyway, I think I got all the info you requested! The answers are included with questions below. Thanks in advance for your help!
Iboats Boat and Motor Info
1. Year, make and model of boat: 2005, Nautic Star 210DC, deckboat
2. Length, width and base weight of boat, look for boat decal on back of boat: 21' L, 102"w, 2650LBS. base weight.
2a.What is the recommended HP for your boat: 200hp max.
3. Number of people and gallons of gas normally on boat: 2-3 peeps, 50 gal fuel.
4. What do you use the boat for: cruising, fishing, mostly coastal intercoastal waterway.
5. Is it a Deep Vee and if so how many degrees of deadrise. It is a V hull but Not sure on deep V question. Manufacturer data not specific and only states transom height 25", draft 16".
6. Year, make and model of motor: 2005 Suzuki DF 140. Direct Fuel injected 4 cycle.
7. HP and gear ratio of motor IMPORTANT. :140hp, 2.38:1 gear ratio.
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range: 5600rpm-6200rpm.
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches:Approx level with keel.
10. Is it a bass boat or does it have a pad bottom. Not bass boat, not sure on pad bottom.
11. Does it have a hydrafoil, dolefin or trim tabs. No
12. Make, model, diameter, pitch and whether SS or aluminum prop. Raptor SS 13-1/4 diameter, 19" pitch
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50: Speed tested with on board speedo, 1 person in boat, approx 45 gal. fuel. WOT = 34mph@5400rpm.
14. Are you at sea level or a higher elevation, give us the elevation in feet.: Sea Level
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM. Tuned up at initial 100 hr. use time. Now at 140 hrs. same performance all the way since new.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop: Prop on boat since new. Not sure is wrong prop but I have seen reports that this motor achieves max HP at 5400-6200 rpm which it won't achieve. Boat cruises well and is easy on gas running in the inland waterway,. Feels a bit sluggish though when in ocean.
17. Does the prop show any damage that you can see: No
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations. I'd like more speed and power especially when used in oceaan, while hopefully not sacrificing fuel economy. I wonder if the engine is struggling with the current prop as will not achieve wot rpm rage.
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
Speed test with 1 person. approx 45 gallons gas.
3000rpm,less than 10mph- won't register on guage
3500 rpm-10mph
4000 rpm-20mph
4500 rpm-26mph
5000 rpm-30mph
WOT 5400RPM-34MPH
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
:I hope I have been diligent enough to get the information you need. LMK if this report is OK.
Thanks for your help!
JGSO
