Mystery vibration
Anthonyd516
Hello all, feel like ive been posting alot of weird issues on here with good results so far. So lets try another. Over the off season up untill now i pulled the engine, replaced the transom assembly, replaced the outdrive (brand new), replaced the steering rack and all bellows are brand new. I took it for its first ride today and it was going great. Untill i took a hard turn at very slow speeds. I got a vibration that almost felt like ujoints. However its a brand new drive and in neutral i can go to any rpm and turn the wheel make the drive go up and down it will not make any vibration at all. I also checked the engine mount bolts to make sure it wasn’t pulling the lag bolts holding it to the stringer out. Anything above or below the 1500-2500 range there is zero vibration. Any ideas?
Hard turns can stress the u joints.
Also, does the outdrive tough the transom mount in a hard turn? I get a little vibration when my OB is trimmed all the way down. it might be the same cause.
Anthonyd516
Hmm interesting thought. I dont know if it does but it is an sei drive. Do they do that?
