Hello all. I was directed here by Andy Nasser from Crowley Marine as they could not provide me an answer.
Ref:1996 Force Outboard 50 - H050412SD [ELPT].
Although this is a Force motor it has all Mercury parts.
When I disassembled the lower unit and the drive shaft, I discovered a 0.060" ring on the drive shaft below the bearing See photo. Can anyone please explain this part and why it is not listed in the parts diagram referenced below.
If I was to simply re-assemble the unit I would not be asking, but I am replacing the drive shaft because of wear at the seals. I suspect it might have something to do with pinion gear clearances?
GEAR HOUSING ASSEMBLY (DRIVESHAFT) - 1996 Outboard 50 H050412SD [ELPT] | Crowley Marine
View parts diagrams and shop online for GEAR HOUSING ASSEMBLY (DRIVESHAFT) parts, 1996 Outboard 50 H050412SD [ELPT]. Offering discount prices on OEM parts for over 50 years. FAST $4.95 shipping available.
www.crowleymarine.com
