Mystery rubber line 1995 Johnson 70
Juddsy
What is the 6" long rubber hose connected to the lower intake manifold (next to the lowest carb) for ?? It is open at ehe opposite end .
Honorary Supreme Mariner
Post a picture of it.----Is there a VRO pump or another pump ?----Is the VRO in service or bypassed.----Diameter of the mystery hose is ?
Juddsy
Its a VRO pump It is in service, just rebuilt fuel pump and noticed this extra. Dia is about 3/8th.
Likely the hose goes to the nipple on the intake air box.
Juddsy
Unfortunately, my air box has no opening. It may have been changed. Since the line draws air it shoild be O K to leave it open. Thks again
flyingscott
At the very bottom of the air box is a nipple for the hose. Or it broke and it is still in the hose.
Rustywrench
It's not a good idea to just leave it open. It can pick up water in the lower pan which can get in your lower crank bearing. Better to put a nipple back on your air box so you can plug it back there.
