Ok took the boat out (87 4winn, 470, Alpha1) noticed I was getting some water in the bilge. Dried it out, thinking maybe bellows, but no water was coming in. Started the engine (in neutral), slow drip appeared at bottom of transom plate, can't see where it is coming from. Increased RPM, leak increased. Put the boat in lift, so that bellows were out of the water, tried again, same results. It is not the bellows, nor the seawater hose in the boat, only leaks when running. Could I have messed up when installing the outdrive gaskets, May just have to pull the outdrive to see what is going on. Any thoughts would be appreciated.
