foxtrotboss
Thread starter- Joined
- Jul 25, 2009
- 46
After reading some threads here and some advice from Frank, I decided it was time to rebuild my 23 year Force 125 four cylinder. #2 cylinder is scored really bad about a 1 inch wide section top to bottom scored bad but has compression of 120 go figure. #3 cylinder has a ring that has broken loose and is coming out the top of the piston with a compression of 75 and lightly grooved wall. I also think by observation so far that the 3 cylinder operates the fuel pump by vacuum.
So after much mental debate I began the tear down of the powerhead. I am almost ready to lift the powerhead off. I need to get a flywheel puller first and finish taking all that under it off. And remove the bolts holding it on.
Then when it is on the ground I'll strip the block and send it to the machine shop.
There really isnt much to one of these motors I am really amazed how simple of a motor they are. Once the block is at the machine shop I will begin removing all the old gasket that is stuck tight. Also going to locktite the reed valve screws, I have enlisted my 12 year old son in the rebuild also, so I will have him chase screws with the tap to clean the threads.
I have read the threads on the three cylinders and I hope this will go as well as theirs. I had my son label all the wired with electricians number tape so we can get them back where they were.
So once I find out what the cyclinders are bored out to I am going to order a rebuild kit. I found one kit online that includes all the pistons and bearings and gaskets. Is there a reason why I shouldn't replace everything possible?
Here is the link to the kit does anyone see why I shouldn't get it?
http://www.powerheadkit.com/images/reman kitforce4-800.jpg
Sorry I don't have any pictures yet but tommorrow I should be able to have some.
Scott
Scott
