Re: My run in with the police... and fire dept... and utility company.
That utility tech is dead wrong.
There is a rubber membrane sandwiched between the cast aluminum halves. There is also an over pressure relief valve.
There is a vent outlet cast into the spring side of the rubber membrane.
If it should get hit with to much pressure from upstream it will vent (burb).
If the rubber membrane were to leak or rupture, it would vent continuously.
An outside regulator will have a screen in the vent outlet.
It is also pipe threaded inside so that if it were an inside installation the vent would be piped to the out-of-doors.
That is a gas industry regulation for safe installation.
By the way the utility tech told me that under no circumstance do those regulators ever burp. You should never smell gas at the meter or anywhere else for that matter.
