my prop size??
verne1972
is there any way that i can remove my prop and figure out the size, pitch ...
there are no number or name anywere.
if i cannot, where would i be able to take it and have this mystery solved???
thanks
Rudy Brown
Re: my prop size??
Their usually marked under the prop nut washer.
Re: my prop size??
You can measure the diameter but you need to have a prop shop determine pitch using a pitch block. But if you look carefully, there should be numbers on the barrel or on the hub behind the nut and washer. Measure diameter from blade tip to prop shaft center and multiply by 2 for a three blade prop. For a four blade, measure blade tip to opposite blade tip.
