My Project
shipwreck
See Pic
1967 Sport Four V-hull
The Owner Had Drill 30 Holes In It All Over The Place And Covered Them With Woodgrain Stickem Strips
The Boat Was Full Of Water (it Drained For 5 Hours) And Tree Flowerings & Chestnuts
Dirty As Pile Of Mud
The Lights Did Not Work
The Tilt Motor Didn't Work
The Lower Unit Screw Was Stripped Out
The Carb. Need Rebuild
Top Needed Piant
Trail Need Lights Tires
Seat Were Bad
This Is Project For 425.00 Bucks
I Just Most Put Time Into ,not Money
Here Are The Result So Far
Bob_VT
Re: My Project
Was the flotation replaced? What about the stringers?
shipwreck
Re: My Project
no,to answer your question, this is my first boat project and the floor seem very solid so i didn't check into those things.
but, i have a second boat that i am doing right now. I have pulled a lot of the floor up and found no foam under the floor at all just open space. the boat is a 16 ft elgin fiberglass v-hull. should i install foam before putting down the new floor ?
