my power cord is cut where do these wires go?
mark ellestad
the power cord to my trolling mmotor has been cut how do i know where to run the wires?ones red one is black andone is yellow(the yellow one is thinner) the trolling motor is a 24 volt minnkota with 74 lbs of thrust. what i need to know is from the trolling motor where do i run these wires? what type of fuse would they need? thank you for your time
EricKit
Re: my power cord is cut where do these wires go?
I may need some more information. Is the power cord connected to your boat cut or to the trolling motor? Is there only two wires or 3? You can measure the lines with a multimeter to see which is ground/neutral and which is the positive voltage if it's on the boat side. Red is generally connected to the positive side and black is the ground. If it's coming from the motor you can often find a wiring diagram online which will tell you which is which. From this you can wire it to your boat and crimp the wires together. If you need a fuse, find out the current draw from the trolling motor (Probably pretty high), and get a fuse a little higher than that. It gets wired in series with the circuit. Going too low on a fuse is never bad, too high can be. Too low just means you blow the fuse early.
