My old 4/6HP 2-strokes won't run.
cloudix
In our area (Lake Ontario) lake levels were high last year and we could not put our docks or boats in the water. So they have been sitting for 2 years. Fuel was run dry last time they were used.
Today I tried to start both the '79 6HP Johnson (6R79E) and the '74 4HP Evinrude (4406R).
Had same problem with both. Could not get fuel to engine. I disconnected the line from the fuel pump to the carb, but only every now and then got a little fuel. Both motors started and ran briefly once they had some fuel.
I have three fuel tanks and two hoses. Tried various combinations but none worked. When I squeeze bulb with fuel line leaving pump disconnected, I hear a swishing sound like air passing through. I also get leaks at tank end of the hose. Hardly any fuel ever gets to engines when squeezing bulbs.
Any tests I can do before I go and buy another hose and maybe disassemble the fuel pumps?
Could I eliminate the quick connect at the tank end so I don't suck air in there? Haven't seen suitable fitting, but presume I just need a 1/4" NPT fitting with a hose barb?
oldboat1
Just as a general point —could be insects, maybe some mold under moist conditions. Might try using a small phillips screwdriver to be sure the connectors aren’t gummed up. A little carb cleaner in the connectors wouldn’t hurt.
In any case, seems to be tanks/lines/connectors, as both motors are affected.
guessing, or course….
cloudix
I will start with a new fuel line. It does seem like the likely problem.
However, both motors used same fuel and were both last used 2 years ago, so it could be something like a gummed up fuel pump preventing fuel from flowing through. Both pumps were rebuilt and worked well before the last season they were run. At this stage unlikely carbs because I have fuel lines to them disconnected. But they could need dismantling and cleaning (even although they have hardly been run since last time they were apart.)
cloudix
Well today I ran some tests holding tank end connectors of fuel hose together. I was able to get some fuel through to the engines. They would run, but if I let go of the connector, air bubble flowed through fuel line and engines eventually cut out.
I put a new tank end connector on the 4HP's hose, And made up a new hose for the 6HP with fixed anti-syphon valve at tanlkoutlet (no connector). Both engines now run!
One other thing I did, is replace the hose from the tank to bulb on the 4HP with a piece of fuel injector hose I had. The Atwood hose was really junk. It had some sort of internal plastic liner that had become detached from the hose wall. No doubt partly blocking flow.
