My little project
Yepblaze
Picked up an old runnabout with a 1960(?)Merc 400 Non thru hub exhaust the other day for cheap $200. <br /><br /> http://www.dgweb.com/~blaze/other/AmericanMarc.htm <br /><br />The boat is a cuty and the trailer fine but the motor has been tweaked by the unknowing not-a-mechanic. Anyway I've manage to get it running, still need to go through the carbs, but the lower unit has me puzzled. I've never personally had one open up before. I do have a manual that shows most other models of that year in general. The unit on the motor is a different color than the rest of the housing.<br /><br />What's happening is the gears shift poorly. Shift tight. And appear to be reversed from where they are supposed to be according to the throttle blocking plate attached to the shift linkage. The prop spins the wrong way and it just doesn't shift right, if, at all.<br /><br />I was wondering if anyone might have seen anything like this before where someone had not correctly installed the lower unit parts or particular parts had failed causing this to show.<br /><br />I'm pretty sure I'll be tearing it down just wanted to know if I should look at any particular parts in there more closely.<br /><br />Sitting here going over the picture book.<br /><br />
alcan
Re: My little project
Hi Yepblaze<br />Dandy boat. Was it that clean when you bought it?<br />Just a guess, I am hoping that the previous owners didn't get the shift linkage indexed properly when they replaced the l\u.
Hooty
yepblaze,<br />Before ya go tearing into that lower unit, post a foto of it. It's probably not but it could be an old speedmaster. Lets have a look.<br /><br />C/6 Hooty
steelespike
If you dont get any help here try Johns Old Mercury Web Site at: www.pfs-ware.com This is an excellent Merc site,lots of links,and smart guys.<br /> Good luck
Bob_VT
Okay dumb thought....could it be a counter rotating motor that was once part of a pair? Twin OB's were very popular in the early 60's.<br /><br />Bob
D
DJ
Guest
I do not believe they had counter rotators back then-outboards anyway.
Yepblaze
It's just a standard non through hub exhaust type from the late fifties early sixties.<br /><br /> I'll get into it in a few days or so. <br /><br />Just was wondering if the symptoms would trigger some old timers lost brain cells and fire off with some memory of a particular maladay.
