My impeller dosent fit into the houseing
fishtricker
:confused:got a water pump rebuild kit and the impeller does not fit into the houseing is this normal the old impellery looks like it diddent fit into the houseing either the blades are bent to allow it to fit wtf is that all about:confused
Cofe
Re: My impeller dosent fit into the houseing
The blades are bent that is normal. Use a little oil or dish soap to help twist the impeller into the housing. Make the vanes twist the same direction as the old ones.
wilde1j
The fingers need to be bent and forced into the housing. Some use some liquid detergent or grease to help. Sounds like you just bought an impeller w/o instructions and have never done this before. Look in the sticky ToP Secret File for more info.
vegasphotoman
ditto.....I wouldnt use OIL though...could harm the rubber...use the soap (dawn/ajax) it will wash out in 2 seconds first start......and is super lubey...use it 100% liquid soap...dont add any water....
the impeller is supposed to rub the inside of the housing......that seals it....and helps make the suction...the reason they go bad is that they lose thier flex and dont bounce back (see the old one is still bent up after you took it out)
Cofe
The instructions for my impeller say to use 30 weight motor oil.....:confused:
Cap'n Chaos
So what if he put the impeller blades in the wrong way.... wouldn't they just correct themselves? Isn't there enough room in the pump housing to allow for that?
Cofe
People say that the vanes will correct themselves if put in the wrong direction.
Myself, I have never put one in backwards, so I would not know the results.
mikesea
I ALWAYS put lite grease inside the pump housing,put impeller on the shaft ,apply downward pressure on the top of the housing ,at the same time rotate the shaft clockwise,I then leave a small space to look and see that the seal didnt fall , .If Im putting a large housing on like a 3 4 or 6 cyl.i put the seal in place with grease or a bit of glue,grease will hold it nicely if the casing is clean ,I make sure every bit of the channel that the seal fits into is packed with grease ,if you rub your finger around it ,its like a pressue that holds it.
vegasphotoman
30 wt oil....I had no idea that would be ok...then again Ive never installed an impeller so Im just using my own thoughts.....thanks for the correction cofe!
bob johnson
the term RUBBER is used in the place of anything that looks similar to RUBBER.
truth is most of what looks like rubber is some other compound, that has way way better properties that old fashioned RUBBER ha ha ha
all the seals made for any tyope of motor or transmission are made from "RUBBER" and they are there to prevent oil leakage or passage..
I would think oil is fine to use on your impeller
bob
ezeke
Actually, "rubber" is a hydrocarbon and oil or grease will eventually either soften or plasticize it. Vaseline is about as bad for rubber as you can get.
It's almost impossible to toatally prevent oils from reaching the impeller, but there is no good reason to add to the problem.
Soap is good, and silicone grease is used in industrial applications: http://en.wikipedia.org/wiki/Silicone_grease
Cofe
I should write to BRP about their faulty instructions for impeller installation, and supply them the link to here.
Tim Frank
There does seem to be some controversy over the effect of oil/grease on rubber compounds used in outboards...even seen a few heated exchanges in here...:eek:
Given that there is also a recurring mantra that you should change impellers regularly,( some even say annually), that should mitigate the risk of deterioration of the impeller from petroleum based lubes.
Fl_Richard
Soap works perfectly and we all have some. I'm definately in the soap camp. Why pollute... even a little?
wilde1j
Impellers are typically molded from Buna N or Neoprene, both of which have excellent resistance to oil, greases and other hydrocarbon compounds. Very little these days is made from natural rubber.
ezeke
Of course, but none of Dupont's Neoprene ads say excellent, they say"good resistance".
kenmyfam
A little dish soap to ease it into place and the first start up on the muffs and it's gone.
bob johnson
if oil really did dissolve rubber they would never make O-rings out of the stuff..
it is used as a barrier to oil!!!!!!!!!!!!!!!!!!!!!!!!
I would have to believe that the material used for impellers is impervious to normal oils..like car oil or LU lubricant.
in any case, you could twist an impeller in place with normal garden hose water... spit is even good
good luck
bob
Cofe
Ky Jelly works well with rubber, and is eco/friendly......:D
