My hubs don't have a seal?
salmonee
I don't think my hubs have any seal? I also noticed that they only have one bearing per hub. Most of the new ones comes with a seal and two bearings. See photos of all the component to my hub assembly at the following thread.
There is a washer that presses against the spindle end.
http://forums.iboats.com/showthread.php?t=326235
bruceb58
Re: My hubs don't have a seal?
The rear bearing and seal is still probably in your old hub.
salmonee
I took both hubs apart right down to the spindle. Both are the same. No second bearing and seal.
Ayuh,... The inner Bearing,+ the Seal are still In the Hub....
Clean the grease,+ $h!t out of it,+ you'll See them..
redone4x4
they dont just fall out, they need to be correctly tapped out with a hammer and a punch. like bondo said, degrease everything and you will see it in there.
salmonee
I found it thanks. Can someone confirm that the spring side of the seal faces the inner bearing?
redone4x4
sounds about right. When you have the seal installed and you look at the back of the hub, you should not be able to see the spring.
