1988 Smokercraft 3.0L I/O mercruiser
I usually didn't take the drain plug out after short fishing trips. But then one day I did...
Went to take my dad to do a bit of fishing. We loaded the gear up and unhooked hold down straps. Backed the boat in and started it up and pulled it around to the other side of the dock because dock is too short to pull trailer out if boat is on same side. Drove the van/tailer parked accross the parking lot. Came back to the boat got in and getting ready to help my dad in, it dawned on me...I DIDN'T PUT THE PLUG IN!! Turned to see the water just coming out from under engine cover and back seats. I took off running to the van at the other end of the lot. Backed the trailer in very fast, went in strait. Ran to the boat jumped into the water at the bottom tried to back up...didn't want to go. So I turned as sharp as I could and ended up getting stuck on top of a stump, got my oar out to push me off. Finally free started to go, thought about doing a speed run to get the water out, but thought I would never get it up to plane. So around the pier to the trailer, drove it on and it went of strait first time!(which is hard with an all wheel trailer) Pulled the boat out. Thank God!! I made it just in time.
After final drops, put plug in and went fishing.
I took about 5-10 minutes for the water to get in and over 40min to let it drain. No damage, just a very wet rug. Next time I took the boat out, I remembered about the bilge pump, what a dumb ass!
nuffa
nuffa
