My boat will not start
CHRIS FANT
I just bought a boat with an older Evinrude outboard motor.It turns over but will not start.It is a Starflite 3 Evinrude I think the serial number is 377095. I think the timing is off, how do I set it?
12Footer
Re: My boat will not start
Welcome to iboats. The timing linkage is pretty reliable on most outboards, and rarely do they 'lose' timing settings. I would suspect everything else first. Try getting a clean spray bottle, and filliing it with 2cycle mix. Spray a few squirts of gas into the carb, and try to start it..If it sputters or runs briefly, the problem is fuel delivery.<br />If it doesn't, check the spark at the plug(s).<br />I'm not familiar with the Year, HP, (and thefore) ignition system type of yuor engine. But if it has no fire, check the kill circuit first.They can sometimes short from corrosion after sitting dormant for a while.
CHRIS FANT
I just turned the distributer a little bit and it started.How do I know where the timing is supposed to be so that it is correct?
