capri_1850SS_lover
Thread starter- Joined
- May 15, 2009
- 20
Took my boat in last fall and got the ?deluxe? winterizing package and the boat hasn?t run the same ever since. With the deluxe package they also inspect and grease the gimbal bearings and u-joints. They called me and said there was corrosion consistent with a flooded engine compartment. I paid them $900+ to replace these corroded parts and then I stored the boat for the winter. This spring it wouldn?t stay running due to a broken terminal on the oil pressure switch which members on this forum helped me identify (Thank you again). Now it starts and runs great on the muffs, but in the water under load is a different story. At low forward speed (approximately idle or a little higher) there is a lot of vibration. Accelerating to mid speed there is some hesitation and then a surge. At WOT the RPMs max out at 6000+ sometimes instead of the normal 4500 to 5000 range. It also doesn?t have the hole shot for pulling skiers like it did last season. I?m hesitant to take it back to the mechanic since he refused to pay for the $32 part he broke (oil pressure switch) when he replaced the oil filter. Is it possible that the stern drive is not aligned or something like that? Any advice is appreciated.
